BR 350 engine
BR 350 engine
Postby WINCHCAT on 19 Feb 2009, 16:50
when we got are new 350 we could do anything with out having it power out now 3 monts later when we start going up a hill it kinda powers out what could be up with that?
a true groomer run with the yellow
WINCHCAT
Re: BR 350 engine
Postby tuckermtn on 20 Feb 2009, 06:47
not sure what you mean by power out...
our 350 has a dial throtle - we set ours at 1800rpm and usually don't have to touch it all night...
tuckermtn
Re: BR 350 engine
Postby Patch on 20 Feb 2009, 15:40
we have had several of these with power issues; all except 1 were theHUI pump
Patch
Re: BR 350 engine
Postby nhmx271 on 20 Feb 2009, 16:46
Is the air restriction light comming on? Even faintly? Have seen a couple of faulty sensors. It is back in the power box in front of the batteries. If it comes on it will derate to 50%. Unplug sensor wire and get on the phone to the svc dept. Can run with it un-plugged.
Craig Racing-When In Doubt,Take'm Out
nhmx271
Manufacturer
Re: BR 350 engine
Postby WINCHCAT on 20 Feb 2009, 23:45
no light comming on or anything but we just gad a new fuel enjector put in so we think that might have an efect on it.
WINCHCAT
Re: BR 350 engine
Postby partylight216 on 22 Feb 2009, 14:17
sounds like it's past due on its service
air filter
fuel filter
oil change
look for the warning lights
partylight216
Re: BR 350 engine
Postby WINCHCAT on 22 Feb 2009, 16:32
but we just got it like 2-3 moths ago
mide you BR didnt do much to it all the bushing wher gone on it and that kinda of stuff
WINCHCAT
Re: BR 350 engine
Postby joshski on 22 Feb 2009, 18:45
How many hours are on it?
Josh Nelson
PistenBully New England
joshski
Manufacturer
Re: BR 350 engine
Postby WINCHCAT on 23 Feb 2009, 13:14
we got it with about 2900 but bow it has about 3300
WINCHCAT
Re: BR 350 engine
Postby Rchristian on 02 Mar 2009, 20:21
We have had all of the problems mentioned and found the 350 is real sensitive to a dirty air filter. Blow one hyd hose in the front and the oil seems to clog the filter. Have also had a HUEI problem early on, repaired by CAT and hasn't been a problem but also hasn't been the same since. I almost wish we had the computer and software to "see" the engine while running. Gonna have to work on that. We did find out that the processor isn't seeing the speed sensors in the final drives. Trying to squeak out the rest of the season till summer service to correct it.
Rchristian
