Pb301b tiller not lifting to the top
Postby chloe on 05 Apr 2016, 00:20
Hi Admin,
Good day!
I have an issue with our pb301 about the tiller. It does not lift totally to the top,it stop lifting at the height of approximately 120cm, after that the tiller cannot move either up or down.It can be move only through bypass
switch inside the Can. And i observed that the LED light of the S3 inside the Can shutted off together with the
S1 LED light,supposed to be the S3 light should remain On.
Can you give me some idea to solve this issue.
THank you,
More regards,
Chloe
chloe
Re: Pb301b tiller not lifting to the top
Postby chloe on 06 Apr 2016, 03:32
hello Admin,
Good day!
After 3 days of thorough troubleshooting in this issue with the aid of the schematic diagram, i found the cause
and i fix it back and now the tiller working so well.
The cause is that one relay that is interconnected to the sensor is not functioning.And that's it.
I am glad to share to you my knowledge and my experiences.
Thanks.
More power,
chloe
chloe
