Hydraulic pumps
Discuss troubleshooting and maintenance of the Kassbohrer family of snowcats here.
Hydraulic pumps
Postby lookout on 14 Mar 2016, 19:49
One of our pb 300's recienly lost power to the right track, and started doing circles mid pass. It seems as if the pump is stroking when no controls are in use, and lurches forward as soon as the parking brake is realised, even at an idle. Is the problem with the pump it's self, or could it be electrical? How do I diagnose, and is there an easy / cheap fix, or is the pump toast? Please help.
lookout
Re: Hydraulic pumps
Postby admin on 14 Mar 2016, 21:13
lookout wrote:One of our pb 300's recienly lost power to the right track, and started doing circles mid pass. It seems as if the pump is stroking when no controls are in use, and lurches forward as soon as the parking brake is realised, even at an idle. Is the problem with the pump it's self, or could it be electrical? How do I diagnose, and is there an easy / cheap fix, or is the pump toast? Please help.
Welcome to the board, lookout. I'd suspect it could be either hydraulic OR electrical, so let's start with a few questions to gather some info for better troubleshooters than I:
What year is the 300?
How many hours?
Sticks or wheel?
Have you done pressure tests on the pumps/motors?
Re: Hydraulic pumps
Postby Yukon on 15 Mar 2016, 12:01
Hmmm, bad EDC possibly?
Yukon
Re: Hydraulic pumps
Postby lookout on 17 Mar 2016, 12:12
honestly, im in way over my head here. pumps have pressure, assuming im hooked up to the right ports. where do i go from here?
lookout
Re: Hydraulic pumps
Postby lookout on 17 Mar 2016, 14:44
ok, now ive got atf coming out of the splitter box and no pressure at the pump. what do i do now?
lookout
Re: Hydraulic pumps
Postby PB400Fan on 17 Mar 2016, 15:15
if worst comes to worst don't be afraid to call PB and talk to one of their service techs, they're usually pretty good about helping you out and can probably help you troubleshoot it over the phone...
Re: Hydraulic pumps
Postby lookout on 21 Mar 2016, 13:56
im ready to set the thing on fire
lookout
Return to Kassbohrer/Pisten Bully Maintenance, Repair, and Troubleshooting
