by cbender on 02 Apr 2011, 11:15
A couple of things that make this winch "new and progressive" for the Sherpa line is the "Wincontrol" automatic feature and the line tensioning system that activates when the rope is not under tension. The first allows the operator to be in several different winching scenarios during one pass and the winch self adjusts based on a variety of inputs. In our 300 PB winch you would have to dial down, then shift power range, then dial back up when you needed the extra pulling force. Apparently in the old sherpa, it was even more difficult.
The new tensioning system allows the lose line to be returned to the spool without birdsnesting or overwrap situations. Though I did not get to do the hook up, it also helps prevent problems associated with loose line there as well. I am not a salesman for Prinoth but I like cats that operate easily and efficiently and it seems that they are moving in this direction with the current changes.
